Hi All, Oz,
No matter how many times I re do the camera alignment I keep getting 1/8-1/4" off alignments of the Y axis. X axis is not an issue.
not sure why you are getting Y axis issues after alignment but there are adjustments you can make on the Camera Control tab. If it’s your Y axis then you’d manipulate the Height scale and Y Shift fields.
At least that’s how I did it but mine was only off by 1mm in X and 1.5mm in Y.
