I recently purchased Lightburn and for the most part I LOVE it.
I’ve watched every video that I can find, and recently purchased a camera for use with my Chinese blue and white laser.
The initial installation went very smoothly. When I click the camera control tab, my camera appears, and I can see my laser bed with no issues.
I was able to calibrate the camera lens, and achieved numbers for each captured image of under .40.
The problem comes when I try to calibrate the camera alignment. If I click the link from within the lens alignment wizard, it asks me which camera to use. I choose the proper camera, then click next. I am then given the option to burn a test pattern. After the test pattern is burned, I click next. the next screen that comes up shows a blank camera window with a button to capture the test image. no matter how many times I click the capture button, no image is captured, and the only option at that point is to cancel.
If I try to click Calibrate Camera Alignment directly from the tool menu, it asks me to select my camera. I choose the correct camera, and a black box opens up. The program halts at this point, and the only option I am given is to cancel.
I’m running Linux mint, 18.3 with an ELP-USB100W03M camera, and LightBurn Beta 0.8.07
Any help you can offer will be greatly appreciated.
