Camera calibration presets
is there a way to save and then open a camera calibration setup. Like to be able to use a 2.5" and a 4" lens and switch back and forth between the camera calibration profiles?
There is in the latest version, yes - If you right-click in the Camera Control window, you can import / export the camera parameters to a file:
The last set imported will be used for the selected laser until you import a different set, or overwrite it by re-calibrating. It stores both lens and alignment data.
Hey Oz!
Sweet! Does this export both camera calibration and camera alignment settings?
Thank you!
Yes - everything you’ve done. If you’ve only done lens calibration, that’s all that will export. If you’ve done both it’ll export both.
So awesome, will save time for sure. Thank you!
