Lightburn v1.103 Windows10 Pro on a cheap micro POS, but it works.
LightBurnLog.txt (8.2 KB)
I got a cheap webcam, Win10 recognized it and it’s feed is visible in the Camera tab (Trace works here, fwiw). Calibration appears to proceed normally with live images visible, but the Capture button is inoperative.
I have attached a debug log, but I believe this is the meat:
20:25:49.560 D: Format: 0 1920 x 1080 @ 30 fps
20:25:49.560 D: Photo: 1920 x 1920
20:25:49.560 D: “enumControls getProcParam 2 failed - Element not found.”
20:25:49.560 D: “enumControls getProcParam 6 failed - Element not found.”
20:25:49.560 D: “enumControls getProcParam 8 failed - Element not found.”
20:25:49.560 D: “enumControls getCamControl 12 failed - Element not found.”
20:25:49.560 D: “enumControls getCamControl 15 failed - Element not found.”
20:25:49.560 D: “enumControls getCamControl 16 failed - Element not found.”
20:25:49.560 D: 11
20:25:49.692 D: “No preview index, falling back to video index\n”
20:26:14.618 D: “TakePhoto::GetCurrentMediaType (preferred photo) failed - The stream number provided was invalid.”
20:26:23.447 D: " – MF_CAPTURE_ENGINE_ERROR - The request is invalid because Shutdown() has been called."
20:26:23.456 D: Clipboard data present:
20:26:23.457 D: ()
I hope this helps!
