Camera Control Window won't come on after turning it off
If I turn off the Camera the Control window, I can’t turn it on again without exiting and reentering the Lightburn software.
Which Version of LB please? also which camera if you have the specs
And what OS :slight_smile:
version 1.4.03
Windows 10 Minius Forum OS
90 Deg 8MP
Chinese
I have been using a Lightburn 4MP camera and wanted better resolution. I haven’t calibrated the camera yet so I am hoping that will solve the problem. Visually the camera is working fine.
Assuming the problem does not replicate with the Lightburn 4MP?
It does replicate but until now I have been ignoring it and using the exit renter technique.
Got you. see if i can repliate it myself
I should add that when I exit it is with a “Lightburn is not responding” message.
To duplicate what I am doing Open the Camera control window then close it again. It won’t reopen.
Sorry, it has taken me a bit of time to more accurately determine how the camera control is failing.
If I click camera control from the big dropdown window it seems to function properly, turning the camera control window on and off. as it should. If I click the X of the actual camera window to exit, that is when it will fails to reopen again.
