I recently purchased the 140* camera and installed it on my laser. The problem is, when I try to do the lens calibration, the sheet with the dots takes up basically the entire shot, making it near impossible to split it into 9 parts like the calibration wants. Should I shrink the calibration image down or what? Anyone ever dealt with this?
You likely printed it scaled to fill the sheet instead of actual size (148mm x 105mm). Yes, you can safely scale it down - the size doesn’t matter, just the area it fills in the camera view.
Yeah it’s basically an entire sheet. Little bit smaller but pretty close.
I will scale it down and move my camera back down to where I want it and see what I can come up with.
Thank you!
