Hey guys and gals. I need help with a Lightburn Camera Set up. I have watched 4 videos to make sure I am doing all the steps correctly and still having problems. Thus the reason I am bothering you all. I have a Lightburn 150 set into the hood of my case.
I ran the setup and got scores all below 0.30, some as low as 0.15. I then ran the calibration and was able to accuratley hone into all 4 cross hairs without difficulty. I then select finished and try to run a test circle inside the circle on the calibration and this is what I get. I have tried both absolute coordinates and user coordinates starting from the home position with similar problem. When I try to position the laser into the crosshairs of the 1 and the 3 it brings the laser to about 4 inches BELOW the mark. I have tried running the calibration 4 times with same result. It worked correctly once when I first installed the camera and then never again. Any suggestions? In one of the photos you can see how far below the center circle the circle actually burned in.
https://www.facebook.com/photo?fbid=4713382945387903&set=pcb.1036244777142222
https://www.facebook.com/photo?fbid=4713382868721244&set=pcb.1036244777142222
https://www.facebook.com/photo?fbid=4713370395389158&set=pcb.1036244777142222
