Camera operation and recognition
Hi - Its David from Plymouth UK again. My original post was about just what to expect from the Lightburn Camera operation, is the image just a “Still” image or should it be a “Movie” image. Immaterial to me at the moment as the camera has ceased to function. Today I recalibrated the camera and it picked up the engraved 1 to 4 marks but on completion I could not get the Camera pane to open. I suspect the computer and/or software does not recognise the camera. It did originally so why not now??? Any advice on this or my previous would be much appreciated.
Thank You, David, Plymouth UK
Still image that you only use to align objects.
If the camera is not detected, you could check if you can change the capture system in main LB settings window (bottom-left).
Hi Misken, Thanks for your reply. I’m delighted to know that I’m making use of the camera as designed. You have set my mind at ease.
