Windows 10, lightburn 1.0.0.3 and 8mp w95 camera. Went through calibration on a 35" wide laser, pattern scaled 260pct. It over sized the image.
Width / Height / shift values should all be zero. You’re scaling up the screen by having non-zero Width / Height values in the camera control window. Those are scaling percentages, not measurements.
lightburn created those values
I can assure you that it didn’t, at least not by itself. If you hover over a ‘spin control’ like those and use your mouse wheel, they may change, which could be what caused it.
The values populate when doing the first step and selecting the 8mp-w-95 calibration preset
If we do the cal preset, then set the values to 0’s, can we then do the burn and click procedure and be ok? The overlay looks to be the right size now. But with the previous burn and click cal, it is still off.
