Looking for some help with selecting a camera. I used the camera selection tool in lightburn and have narrowed it down the following options. I have an Omtech 2028. Where I’m stuck at is which lens angle do I go with and does it really make a difference? Just looking for some better image quality. Thank you!
I always want to choose the smallest possible wide angle, but that is (also) determined by the height from the work area to the lens.
Learned that. The 1Laser came with the UH cam mounted inside. 22mm too close to the bed. I moved it to the top of the lid. Works now. More than once they screwed up.
Don’t think I am defending them but they likely made an assumption on how the camera was going to be used.
Your generous Mikey. FYI stay away from 1Laser.
