they look fine and measure 150mm x 35mm but burn at like 10mm wide. I tried everything … i think. Soooo frustrated. thank you please?
Is this new problem?
New machine?
Do you use rotary?
its old machine but seemed to work fine. it ran wheel nc perfect a few days ago but since then everything is super small and i dont know what rotary is. i ran laser grbl , candle and lghtburn.
Can you enter $$ in console window and paste results?
Can you also do a screenshot of desktop with move window selected?
will do thanks stand by.
$0=30
$1=255
$2=0
$3=2
$4=0
$5=0
$6=0
$10=3
$11=0.050
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=1
$24=25.000
$25=250.000
$26=100
$27=1.000
$30=1000
$31=0
$32=1
$100=100.000
$101=100.000
$102=50.000
$110=10000.000
$111=10000.000
$112=1000.000
$120=5000.000
$121=5000.000
$122=5000.000
$130=600.000
$131=600.000
$132=30.000
Not seeing anything. Others more knowledgeable will jump in.
Do you have a sample of the project that has the problem?
Looks like you have ball screw drive so your $100 and $101 numbers of 100 are probably right.
its just a 3/4 inch by1/8 inch burnt spot on wood that is sort of divided into 5 parts . see pic
If you make a 100mm x 100mm square what size does it burn?
it makes an 1\8" dot
Or maybe 1/6th of an inch dot? Seems close enough to a factor of 25.4 for unit conversion error to be the likely culprit.
Your posted GRBL settings are the original ones?
First change the settings per the following values:
$100=1600.000
$101=1600.000
$102=1600.000
$110=1100.000
$111=1100.000
$112=1100.000
$120=3000.000
$121=3000.000
$122=3000.000
$130=290.000
$131=170.000
After a few tests you can change
$0=10
$12=0.020
if nedded.
A bit more info on GRBL settings.
https://github-wiki-see.page/m/gnea/grbl/wiki/Grbl-v1.1-Configuration
