Hey there I have a OMTech K40 C02 laser and I’m cutting/engraving on 1/8 acrylic. I use Shapr3D to make my DXFs i’ve only ever done cutting and single layer engraving before. I was wondering if I had an edge that I wanted to chamfer is there a way to make like different depth engravings to get the result? same with say a hole Id like to try and countersink?
I would say you are looking at a CNC process.
Most lasers do not work like a drill or milling machine, at least when it comes to chamfered holes or edges.
To do this with a co2, you’d need a grayscale drawing of it going from light around the edges to dark in the center. May not need a center if it’s a screw hole.
I don’t know any other way to accomplish this type of operation.
Hang in there and see if others come around and put their 2 cents in..
Up to a certain thickness, depending on your laser power and the edge width you want to remove, it can be done with a jig. “Deep engraving” the material away is not very suitable. Making countersunk holes for screws is possible, but is not worth the effort. A few times I have engraved holes for umbraco screw heads, but only because I did not have the right drill.
The parts you show should be suitable for cutting the edge off with a small jig. I once had a small production of 5mm plates that needed all edges broken at 45 degrees, it worked fine with my 60 Watt CO2 laser.
…I can’t find my little jig that I used this time but found an example with the screw holes and “depth engraving” for rulers.
If you need help making that jig, let me know, but it’s really simple, it’s just a matter of setting up your workpieces at the angle you want to cut.
Obviously more than one way to skin a cat..
I’ve never really been able to remove any reasonable amount of metal material with my co2. You’re doing this with stainless?
I tried to make something, quite a while ago with the co2 and a stainless strip. Although I got a mark, it wasn’t very good and really didn’t remove much material if any. I did burn up that lens for the trouble.
Thanks for chiming in…
As everybody has pointed out, laser beams lack depth stops. ![]()
The grayscale technique works, but the depth is strongly nonlinear with respect to the layer power percentage. A 10-99% grayscale bar pattern produced this sculpted result:
The rough bottom suggests it won’t be useful for exposed surfaces. @bernd.dk’s angled cut will be much better.
There’s a 1.5 mm rebate around the back of this test earring for the “gold” ring and a recess for the wood veneer inlay:
The ragged edge on the rebate shows why I pretty much gave up on that idea.
So I’d say depth control can be done, but you gotta have low quality standards to accept the result. ![]()
You must have misunderstood something, it’s acrylic I (we) am talking about, not metal.![]()
My mistake, sorry about that…
…no problem, it would be great if we could handle metal ![]()
Look here.
…time goes by so fast, I’ve already forgotten about this thread - but I still use some of it, as can also be seen in the picture ![]()
