Can I save my art library to use on another computer running lightburn?
I am thinking that i may need to uninstall and reinstall Lightburn on my PC. I dont want to lose my entire art library again. Is there a way for me to save my art library for later on the reinstall and also use on my other computer that i run lightburn?
Kurt, you have the option to export/import all or part of your settings, including material and art libraries.
LightBurn Art Libraries are individual files with .lbart as the file extension. You can store them where you’d like and just need to inform LightBurn where you have saved the file using ‘Load’ found in the lower-left of the ‘Art Library’ window.
Loading and Unloading Libraries
You can Load libraries that have been shared with you by other users, created on another computer, or were previously removed to reduce clutter.
To Load a library, click the Load button in the bottom of the Art Library window, then navigate to the location the .lbart file you wish to load is stored, select it, and click Open.
To Unload a library, first select a library from the left side of the Art Library window, then click the Unload button in the bottom of the window. Unloading a library removes it from view, but does not delete the file or its contents from your hard drive. You will be able to Load it again at a later time.
