Currently taking 11:44 with a 90w laser. Is there a way to speed up time without just going faster?
Rose with Name Bella.lbrn2 (164.6 KB)
Thanks.I never used that before. Will the result be any different?
you can try with some circles, if the line spacing is not too big it will be fine
It cut time down almost in half. Thanks!
What font did you use for “Bella” ?, I wonder why you have that line through “B”
The font is called Monday. I don’t like that font either because of that. Do you know a better font I can use?
Wouldn’t take much to edit out the line if you otherwise like the font.
I love “Snell Roundhand” but it’s a little too thin for the purpose of the rose, and as @berainlb says, with a little manual fine-tuning it goes well enough.
I need to beef up the bottoms of the letters somehow where they connect. i cut out a rose and the name is just too flimsy
try using susa heavy font
