Hi - I am just about to order an Atomstack A20 Pro 20W Laser Engraver - I only have a desktop PC in my home office and the Laser Engraver will be in my workshop the machine has an offline controller so my question is can I generate the required code in LB and then copy it to a card and insert it in the offline controller - Thanks in advance & Happy New year! - PS this is my first Laser machine and I’m a retired old geezer so any help will be great
I believe this is possible.
- Use File->Save Gcode or “Save Gcode” in Laser window to save the gcode of the job to a file
- Transfer file to SD card or whatever other method your laser uses for offline access
- Insert SD card into offline controller, pick the file, and burn.
There’s likely a specific procedure you can use to frame the job on your laser so check for that.
Thank you I’ll give that a go
I have loaded up LB demo and I can set up manually - my machine isn’t listed but there are 3 GRBL options - grbl - grbl-lc - grbl-m3 does anyone have any clue which is the right one for the Atomstack A20 Pro 20W output
GRBL is the right profile.
Once again thanks for your help - Cheers Geoff
