Can not get Library to show on tab on bottom right next to Art Library | Laser
I accidentally hit the minimize button on my library and now when I tap window on the top tabs and select Library it shows my library but I can not get it to show up on the bottom right hand corner as a tab to select through my art library, laser etc. I tried to double click the header on library to turn the top red to drag it down and it snap in there but it will not work and help its driving me nuts
If you double-click the title bar it should snap back into place without dragging. Try just grabbing the title bar and drag it to the window where you want it.
thank you I ended up closing the program and trying again and it worked.
