My laser connected via LAN worked well but now it doesn’t work anymore .The program says “there is a problem sending to laser.Maybe the device is busy or paused”.restart does not help Hit Esc multiple times on my machine but still keep seeing dimensions at the bottom of my ruida scream . I think there is still a temporary file , can’t I delete it?.Can someone please to help?
I’ve been getting a lot of disconnects and jobs randomly not able to send after upgrading to 1.0.6
Are you using USB or Ethernet?
LightBurn 1.0.06, built Sat 2021-10-02 @ 13:40
Via the Lightburn bridge. No issues…
What changed? Usually something has changed. If not, it’s probably broken hardware…
What file do you see and where?
