I can burn from the home position, but if I move the laser out to center on a piece, I get this error message. “There was a problem sending data to the laser.” I’ve already tried using tips from the forum, but nothing works.
There’s a bug in Ortur’s firmware that’s causing LightBurn to lock up waiting for a reply. This has been addressed with our next release which I’m hoping to have out very shortly.
Any idea when the release will drop? I am working on a project that needs to start from the middle.
Thanks
Try this:
- Go to Edit > Device Settings
- Enable $J jogging
- Restart LightBurn
- Go to the Move window
- Enable ‘Continuous Jog’
That should bypass the bug that’s locking the UI and get you going again. We should have this out shortly, though I’m trying to nail down a different issue that’s causing another GCode machine not to connect.
Thanks - for the quick response as well as a great product…
