Hello there, I’m having an issue with the working surface of my laser. I have the dimensions setup as 500mm x 400mm as it should be, but I can only use the right half of my working surface. “0” on my grid in Lightburn (all the way to the left) ends up being about the middle of my working surface. Any suggestions?
Have a look here to ensure you have things set up correctly. https://github.com/LightBurnSoftware/Documentation/blob/master/CommonGrblSetups.md#common-grbl-setups
If your device doesn’t have homing you’ll need to manually move it to the front-left before powering up, or jog it there and use G92 X0 Y0 in the console (or a macro) to set the origin there.
