I am cutting out a very large grid of small tags, so the lines traverse a full 25" or so. It needs to be cut in two passes and currently the head is moving to the end of each line, making a cut then moving all the way back to the head instead of reversing and making the cut on the way back.
It sounds like this does not happen on some controllers but does on others. Is this something that is unsupported on Ruida controllers?
That will run the line in the reverse direction, though looking at the preview, it might not be planning the entry point for the next line correctly. Try it, and I’ll make a note to check the code.
