New problem using 0.9.10. With mini gerbil on a K40. Shows error:24. When it stops. Won’t restart after that. Tried different files all stop about 60% through. Help?
Error:24 - Invalid gcode - More than one g-code command that requires axis words found in block.
LightBurn doesn’t create invalid gcode, so you have a wiring or grounding noise issue.
Well that’s great. I guess I’ll get another usb cable. Other than that I’m lost cause nothing’s changed
It’s a pretty easy thing to have break. Especially if it’s older. And it’s almost impossible to tell from looking at it, unless it’s really trashed. You’ll also want to make sure it’s as short as it needs to be, and isn’t over 15 feet long.
