Hi all,
I m tryng to change my controller to a Ruida 6445G (had an old chinese controller for CNC that someone adapt to Laser). The X and Y axis are ok, the limit switch are ok too… but i can t put the laser tube working… it only fires when i press then test button on PSU!
I did this wiring:
IN goes to PWM1
G goes to GND
TL goes to LON1
the wires that comes from the valve of the chiller goes to WP1 and GND…
can´t have it working, already tryed to change the signal to LOW and High, enable/disable water protect on lightburn, increase minimum power, but nothing happens, no pulse and no power when i send a file…
can someone help me??
thanks in advance
