can you cut any plywood or do you have to get laser plywood
Laser grade plywood will have been manufactured using an adhesive that is not dangerous when zapped with the laser. The adhesive will also be of a substance that can be easily cut by the laser. The plywood will have fewer (or zero) voids in the material, which cannot be said of generic plywood.
It is not a certainty that a specific grade of plywood is unsuited for laser cutting, but one takes one’s chances if the material is not stated as laser-grade.
Thanks for the answer
6mmPlywood.lbrn2 (27.2 KB)
@Bat21UK Try this it will give you a starting point. this cut’s perfect on my X7
thank for the help
