Flavi
(flavi)
1
Hello,
I have an issue with using hotkeys for assigning colors (C00, C01, etc.) in LightBurn.
I cannot get any shortcuts to work for changing layer colors.
What I tried:
assigning shortcuts like Ctrl+7, Alt+1, etc.
selecting objects before pressing the keys
testing both number row and numpad
The shortcuts are accepted in the Hotkey Editor, but when I press them, nothing happens.
Questions:
What is the correct way to assign working shortcuts for layer colors?
I really need a reliable way to quickly assign colors to layers.
Thank you!
ednisley
(Ed Nisley)
2
Windows has so many predefined shortcuts that it’s likely capturing those keystrokes and not passing them to LightBurn.
A casual look at the Microsoft shortcut list says Ctrl+digit combinations move through dialog box tabs.
Unless there’s a way to remove the existing system-level keyboard shortcuts, LightBurn won’t get them.
Aaron.F
(Aaron)
3
I can assign and use Ctrl + 0-9 to quickly assign selected shapes to the layers on Windows 11. Worked with both the number row and numpad.
Which Windows version are you on?
I had to clear two already used shortcuts to assign 0-9 to all the layers.
You can change the fileending of this file to .lbhk and import it.
LB_Hotkeys_Layer_Colors_0-9.txt (581 Bytes)
Flavi
(flavi)
4
I do use windows 10. Thank you so much Aaron
system
(system)
Closed
6
