I have the same version of lightburn on my PC and laptop. On my laptop I can edit the clock numbers (created by array function) which all come up as 12 all the way around the clock and then I individually change each number 12 to the proper number 1,2,3, etc. Simple, that’s how it should work. BUT, when I do the same thing on my PC I can not edit the numbers, they all stay at 12. What’s up with that?
When you open the file on your PC do you get a message that the font is not found? If the font is not on both computers Lightburn will convert the numbers to a shape and they are no longer editable.
i do get that message but its a font i do not use or even know what it is
When Font is not found, LB changes from text to path… It is no longer a text field, rather the numbers are just shapes (aka: objects).
You have to install that font on the computer to be able to change the text.
