I cannot change the job origin! It used to be in the settings but no more.
Next to the co-ordinates is a box with 9 switches which I think is the job origin but I can change it as I like, it stays top right corner (the green block)
I use “Start from origin”. If I change it to “absolute co-ordinates” it moves to the left bottom corner which is correct. I looked everywhere, also FAQ but nothing.
The nine-dots you’re showing there let you choose where resizing and rotation happen from, when using the numbers on the toolbar, so you can scale from middle (default), or any corner or edge.
For tabs, the simplest way is to use the boolean tools to remove a small portion of the characters, like this:
Draw your text:
Add some rectangles where you’d like the tabs:
Group the rectangles together, then select the text, then the rectangles, and click the Boolean Subtract button (or Alt -):
