Trying to engrave a photo. I can change the power but not the speed. It goes way too fast. This worked 10 min ago. I lower it to 1 mm/sec and it still flies across.
Can you provide a screenshot of the cut settings you are using and some information on the laser hardware (you have a couple different listed on your profile)?
Are you changing the speed entry in the Move window? (that’s for jogging) or in the Cuts/Layers window? (that’s for the cut, and can be set for each part of the job)
These are the ones you want to change:
Well it works today. Baffled!!!
