Cant convert traced image to path to apply nodes
Hi I know this is a simple thing but a search has not found a solution I have a shape on single shape and I want to apply nodes to edit it but convert to nodes is not available. The shape is ungrouped ie it is just one shape. Little things like this are quite frustrating thanks for your help.
Did you do Edit> “Convert to Path?” First?
Can you show a screen shot of your LightBurn window?
There are a number of reasons it might not work, so providing more information would be helpful.
Thanks for the quick response guys, in the end it seems it was already in the mode to edit nodes but I had to go to tools and optimise shapes to lower the node count so I could see it clearly. Thanks again
