Cant get lightburn to load
cant get lightburn to laod after getting new key code
Not much information to use for diagnostics.
Tell us what steps you did, and what worked AND did not work. Include messages on your screen.
i loaded lightburn new patch and got my key code but when start lightburn to put in the key code knowing come up it just sit there spining and thinking
You did not say what you were patching. If you are jumping a couple of versions, you might try this:
Reinstall Lightburn after.
https://aka.ms/vs/17/release/vc_redist.x64.exe
https://aka.ms/vs/17/release/vc_redist.x86.exe
that did not work
Just had a thought. Go in and empty the Recycle Bin.
Hopefully somebody else will join in with suggestions. I am pretty sure the problem is with Windows and not Lightburn.
Did you try going back to a previous version of Lightburn to see what happens?
when i try to load Lightburn on the 4th window open and says the following application are using files that need updating by setup it is recommended that you allow setup to automatically close these applications after the installation has completed
Check Task Manager for running processes…
Also check your Antivirus, Firewall, maybe you default / set rules that are blocking internet access and pending actions.
