Can't get the inverted image into the work area. Making a pcb
I was able to invert the image using the Tools/Adjust Image - Negative Image button. I can’t save it nor does it show up in the work area. It shows negative in the “dialog box” as expected.
Thanks
Mark
What does it preview as?
It displays as black background with white traces (PCB) in the right hand window of the Adjust dialog box. The Keycad plot is white background with black traces
If your design is an image, there is the Negative Image switch in the Cut Settings Editor window for your convenience.
If your design is a vector (path) then add another box around the board outline using Offset Distance = .001mm in the Offset Shapes window. Then turn on Fill, if not already on, and everything will flip.
