Can't get the laserhead to cut a full square
I am trying to cut a 4 inch square out of 6mm birch plywood and the cutter is only going back and forth on the bottom cut line. I have shut down the laser and restarted it and it still will only go back and forth on the bottom cut line. What can I do to correct this problem. I am using a Falcon CR10 Laser. Thanks in advance
Can you jog it in the x and y axis? If you move the 4 inch square up by an inch (or right, depending), does the position it goes back and forth on move? I suspect that one axis isn’t responding, could be a loose wire or something similar
Thanks I will try that.
Be absolutely certain Rotary Mode isn’t (inadvertently) turned On, because it changes the Y axis settings.
If you don’t have a rotary and, thus, have never done the setup, the results can be … disconcerting. :grin:
Hi JamesG57. Yes I had the same problem on my 130W. All setup, pressed start and it did the same thing. If your laser has a switch for doing rotary work, make sure it is turned OFF. Also check the machine settings setup.
Laser4
