As title suggests, updated from AI2019 to 2020 and still cant import AI files.
If i export it to SVG from AI20 and then import in LB it loads correctly.
The AI file importing has an Array and a few shapes, but nothing too complex.
Disable compression when you’re saving the AI file.
Are you using version 9.09? Version before that have a problem with Illustrator 2020 files.
Blake and Patrick are both correct. 0.9.09 adds detection and graceful abort of the new compression method in AI 2020 files. If you save without compression, or save in a legacy AI format it works, as does updating to 0.9.09.
