why cant i create a pocket outside of a imported Jpeg , i use jpegs for my depth maps 4 3d carving , but unlike an STL file i cant create a pocket out side of jpeg ? why is this.
i know i can create a rectangle same size as jpeg than create pocket
but would be nice just to use jpeg boundary
Trace the image, select the trace and the oval shape and assign to a Pocket Op.
yes that is another way can be done, But when tracing it doesn’t always create a perfect closed outer boarder.
doesn’t answer Q of why cant boarder of Jpeg just be used
I used the offset shape tool and then made a pocket with that.
I think it won’t work with a jpeg because it’s a bitmap and the pocket tool needs a vector image to work.
You can offset shape Outward to a closed shape with Delete option ON, then offset Inward the same amount.
oh yeah dah silly me
