Cant seem to weld shapes? Wanting to remove the tooth shape from the bat and hat
Hi Can anyone tell me why I cant weld these shapes? Thank you!!
Consider to upload your file, but also describe the steps you are performing to attempt to weld the shapes. If anything is grouped, you will not be able to perform some boolean operations. If some objects are not closed, some boolean operations cannot be performed.
I can’t see any reason that wouldn’t work just from looking at it. When you try to weld them, what happens? Because the tooth is actually two shapes, one inside the other, it might be better to make those a group, then use the Boolean Union tool.
Thank you! I played around with the groups and somehow made it work… more practise I think :blush:.
Thankyou this was very helpful :pray:t2:
