Can't select individual designs after copy/paste
Making a bulk order of divot tools and I’ve copy/pasted the first template to fill all of the rest. I am unable to select just one to etch. They’re all on the same color/settings. If I only select the lower left, it etches all of them starting in the top right.
I’ve turned it all off and on, updated Lightburn, but the problem persists.
It always helps with these problems if you can supply the offending .lbrn2 file…
Removing and reinstalling packages is generally of no use anymore. I don’t even consider it as a viable option. I think it came from the DOS days…
Tell us more about what it’s doing and some screen shots are valuable.
When you import/select the object is it grouped? Try un-grouping the objects.
