Cant use inches in Test Generator
I researched and found this dead end as the generator does not switch when settings switch… Test generator, mm to inches
How can you make the generator use inches?? or SAE in general
These machines all use mm and I believe Lightburn uses mm internally.
I’m running a beta version, but it works like in the link.
This apparently isn’t applied to the height/width and center values.
Can you show us a screen shot of what isn’t working?
