Hi everyone,
Out of every 100 support inquiries we get, a big chunk are people with a dying or weakening tube, and the very first request is almost always:
“My tube is losing power — can you just open it and refill the gas?”
Sometimes they ship the tube back to us. Sometimes they’ve already tried prying it open themselves. We see this happen constantly on the factory floor, so I wanted to explain what’s actually going on — because refilling almost never works, and a lot of people waste money trying.
Why you can’t just “top up” a sealed CO2 tube
A sealed glass CO2 laser tube isn’t a bottle of CO2. It’s a sealed vacuum device built around a precise gas mix (CO2/N2/He in specific ratios and pressure), sealed electrodes, a catalyst layer, and matched optics. When we make one, it goes through vacuum pumping → precision gas filling → sealing → performance testing, all in one continuous process. Once it’s fused shut, opening it and putting gas back in means redoing that entire production line, by hand — and the old tube’s electrodes and optics are already contaminated, so it will never perform like a fresh one.
But here’s the part most people get wrong
When a tube starts weakening, the gas is usually the last thing to blame. Before writing off the tube, we tell everyone to check these first — because we’ve diagnosed countless “dead” tubes that were actually just:
- Dirty mirrors / focus lens — the #1 cause of “my laser got weak.” Smoke residue kills transmission and it’s free to clean.
- Beam alignment — a drifted beam cuts poorly and looks identical to a dying tube.
- Cooling water temperature / flow — hot or low-flow water throttles output within minutes. (Note: the cooling water is separate from the laser gas — it only circulates through the outer jacket.)
- Laser power supply — an aging or mismatched PSU produces the exact same symptoms.
- Running current too high — overdriving the tube ages it fast.
We’ve had customers ship us tubes they were convinced were finished — and after a clean, an alignment, and a PSU check, the machine was cutting fine again. That’s the whole point of the diagnosis step: don’t buy a tube you don’t need.
When the tube really is done
If optics, alignment, cooling, and PSU are all good and you still see fading output, unstable performance, rising operating voltage, or abnormal discharge — then yes, the tube has reached end of life and it’s replacement time. When you do replace, match more than wattage: dimensions, electrical specs, cooling needs, optical config, and PSU compatibility all matter.
