Center of rotation?
any way to move the center of an object so you can use it as a new pivot point for rotation and mirroring etc. Then reset center when your done?
Try this.
That might work but limited to the corners. I made a cross from two lines and made a null out of it. Now in circle array select the object and the null last and now it becomes a new center of rotation. Kind of a work around. Thanks for your response. Maybe it needs to be a feature in the next release.
Arrange > Two-Points Rotate / Scale, a feature I discovered recently in this forum.
