I downloaded the pre-release that includes nesting and also centerline. I tried the centerline but every time I try it I get these little lines off of the main centerline image. Like little hairs. I’ve tried numerous combinations on how to just get the centerline without all of these line artifacts off of the main centerline image – to no avail. Is there any way to add this remedied and if so, how?
How well this works depends on the quality of the lines in the original image. If you zoom in and see a gradient of shades beside the main line, you will have an issue. If you do not have a 100% white background, the Trace Mode can pick that up too.
You might be able to adjust the image in other software to get nice crisp lines.
Can you post your image so we can see what you are trying to process?
Thanks for the info. I usually take an image and put it into Photoshop elements and make sure it’s 100% black with a complete white background. I’m not sure the image that I tried the centerline on was put into Photoshop elements prior. I’ll test it and if it still does what I think it may do, I’ll post the image. Thanks again.
I don’t think so. The Docs gives a good explanation on what to expect with this mode.
