Change all nodes of one curve to the same type
Is it possible to somehow change all nodes of one curve to the same type, for example smooth? I mean all at once, not by clicking on individual nodes, of which there can be many.
You can drag a box around nodes to multi-select. That may not fit every scenario, but does often come in handy.
Aaaand Ctrl and Shift also work during node selection!
Thank you for your reply. I know how to do a multi-select. My problem is that after I do a multi select, I need to mass change the type of all the nodes to the same type. And I don’t know how.
I’d’a sworn I hit S to smooth all the selected nodes in one swell foop, but my remembery has apparently broken, because that (no longer?) works.
Paging @JohnJohn: It should work that way, even if it never did. :grin:
:+1:
The only thing you (I) can do with the selected nodes is to move them, for example with the arrow keys, which is very useful, or delete multiple nodes.
You can use Edit>Optimize Selected Shapes to reduce nodes within a tolerance
Classic!
Soon to be Classic! (If it’s not a Classic already… Not sure… Can’t remember.)
Should?!
I make no such moral judgements about software or other technical things. :grin:
I’ll ask about the S for smooth nodes in LightBurn and if anyone here has seen this feature in other design software.
Given that hitting S with one node selected smooths the curve at that node:
It seems reasonable to expect hitting S with many nodes selected should smooth all of them. Heck, if hitting D deletes all the selected nodes, smoothing them should be straightforward.
Stipulated: Nothing is difficult for the bystander who isn’t doing it. :grin:
I’m on mobile and hadn’t tested it but maybe pressing S and a modifier key or two sametime (CTRL SHIFT ALT).
