Would be great big we could change the default export from .ai to .SVG… Or simply remember the last one selected? As I’m using an external nest program, I export everything ,nest, then import… The nest software I use, only works with SVG…
Thanks
Thanks
I always intended to do this, so this was a good nudge. It’s been added to the upcoming release. It simply remembers the last export type you used - if you only ever use SVG it will always default to that.
Excellent, really appreciate this… Thanks ! The obvious next question is when is the next release lol ?
Unfortunately the obvious questions have obvious answers: when it’s ready. I don’t promise set release dates, because they always slip, but it should be soon - a week or two hopefully.
