Is it possible to change the parameters after i have set a array. Sometimes i will change the distance or the number of rows but i don’t now how to?
No, not as you are thinking. This information is not retained for later adjustment. Once you click the ‘OK’ button the array is built based on the parameters you provide and each resulting element generated by the array process is an independent copy of the original.
Unfortunately. Somethimes i make an array and afterwards i think, in can closer or i can do one part more. But, anyway, maybe in the future?
Thanks!
