Change size of image failure when preview or laser cutting
Sprygel A2.lbrn2 (11.5 KB)
[quote=“GatewayCustoms, post:1, topic:135381, full:true”]
So, when I change size of the upper object it looks OK in Lightburn, but if I try to cut or open in Preview it change to something else, I cant find what create the error when change the size of the smaller object ?
//ERIK
It’s not clear what you’re referring to in terms of the change. But I suspect what you’re describing is due to the kerf setting that you’ve set on the Cut layer. The kerf setting changes the path of the cut to accommodate for kerf. You may not be anticipating that.
Remove the kerf on the Cut setting to confirm.
Yes, It was the Kerf setting that was my problem when cutting with my laser, thanks for fast solution.
