Change start point issue (For me at least)
When selecting node edit mode, I can see the current ‘green square’ cut start points.
If I set shape start point/s to a different node which is indicated by the blue arrow, when I check in the preview the start point/s are correct but I would have thought/liked the new start point position would have been reflected in the node edit mode which it is not?
Perhaps I’m just going mad…comment’s welcome thanks :upside_down_face:
The start point (blue arrow) and shape start point (gren box) are not the same thing. The green box is determined by how the shape was made. The blue arrow does go to this location by default, but it can be changed to any other point as you found out. If you want / need the green box to align with the start point, using the node editor select the point you wantthe green box, break apart at that point then rejoin the shape and that point will be the new location of the green box. That will also move the blue start arrow to that location. But like I said they are independant of each other.
Thank you for taking the time to give a comprehensive reply :slightly_smiling_face:
It seems that whilst your reply was quite correct I have now discovered that I was chasing a wild goose (The green node)
I have now learnt that when clicking on a shape (In The Set Start Point) the default start point is highlighted with a grey arrow and clicking on another node will move the default start point marked with a blue arrow. I now realise I have never seen said grey arrow so that’s where I was getting thrown off. So the question is why am I not seeing the grey arrow?
This is from Millmage documentation.
Hero Image
This is from my desktop, green node where grey arrow should be?
I am not seeing this is in any version after v0.8.02 MillMage. It could have been appearing in an earlier version and the Docs have not been updated.
When reading the Docs be aware things can change and not make it into the documentation yet. This is expecially true with MillMage where the enhancements are arriving at a machine gun rate.
