Changing Bridge to new network
Goal: Bridge is connected to “Home Network”, and now I need it to connect to “Office Network”. I’m having a very difficult time finding information on Changing the network that my Bridge is connecting to. I can’t access the Bridge wizard through Lightburn, and since the bridge is already connecting to a network, it can’t be found in network settings.
Is re-flashing the only way to reset the bridge? I was apprehensive to do this, I didn’t know if it has information I might lose, information I shouldn’t lose. So I’m posting to understand before doing any re-flashing, and see if there’s another way.
I’d suggest trying to setup the wifi manually:
Advanced LightBurn Bridge Setup - LightBurn Software Documentation
In the worst case the Bridge will revert to defaults and you’ll go back to connecting to the Bridge AP but if all goes well it should simply use the newly configured wifi.
Even if you have to reflash there’s not a whole lot you can lose, especially if your laser IP is configured to the default 10.0.3.3.
Thank you! Will try this evening and follow up. I deeply appreciate it!
Very straight forward. wifi.txt worked great! Thank you.
