Hello,
I am looking to change my rotary from a chuck to a roller. I engrave glassware. I have the laser script LS6840. Would anyone have any idea on how I find a compatible one?
Thank you
Hello,
Thank you
Depends on how much you wish to spend…?
I have the PiBurn rotary, that I like very much, but it’s not low cost.
It has adjustments and hold downs in areas that are problematic in normal wheel rotary setup…
Mine plugs into the Y axes, but any supported axes w/motor driver should work.
It should be an easy addition…
I assume this is some type of DSP controller?
Good luck
