Changing driver from EzCad2 to Lightburn on Fiber Laser
Hello, I have a Flex laser, fiber 50W. It currently uses Ezcad2, but I want to change to Lightburn. Is there some literature to help?!?
Self-Made Fabrication LLC
Give this a read, hopefully it will help
It’s all there in the Doc’s dropdown menu, top of this page
I have another laser CO2 with Ruida already using Lightburn. trying to add this as a second.
As long as you’re using a version of LightBurn with Galvo capabilities, your existing license key should work without issue. Select the ‘Devices’ button, then create a new device manually or Find My Laser
We have a video walkthrough for first time galvo setup here:
that was the answer to my problem. Thank you for the video!! i just needed to download again. this should not affect my Ruida Co2 correct.
I appreciate the timely support
I wouldn’t think so, they don’t use the same driver as far as I know.
You should connect to your Ruida via Ethernet.
A lot of people find this handy.
