General question:if I change the settings while the laser is cutting (such as speed), will that affect the cutting already in process? Or will the cutting settings remain as they were set at the beginning of the process?
No, once the job is started the changes you make to the workspace will not be streamed to the machine.
HOWEVER **
Under the MOVE window on the right side of your screen, once the project starts to stream you can increase/decrease speed and power and have almost immediate changes. BUT it does not change the design file.
Yes, that’s my understanding too. Changing the settings in the workspace after a job has started won’t change the settings that were originally sent to the machine. The controls in the Move window are different since they can adjust speed and power during an active job.
This is pretty useful when dialing in a new material. I’ve been looking at the Monport MEGAS, which has LightBurn WiFi, autofocus, and a wireless camera, so it seems particularly convenient for testing and fine-tuning jobs without constantly stopping to reposition or refocus.
As the others have stated, you can change settings in the move window while a job is running, but this only applies to jobs that are being streamed from LightBurn.
You would need to have your laser connected and select “Start” in the laser window to have a job stream from LightBurn to your laser.
If you press “Send” or “Save Gcode” in the laser window, the job parameters cannot be modified from LightBurn while the job is running. If your laser controller has a screen or other interface, you may be able to change parameters there, but that will depend on the make/model of your laser.
I seem to be having problems whenever I change speed, it shortens the project by several mm. If I’m jumping topics please let me know I open another?
Please give specific details and post a file that exhibits the behaviour.
Unless you have a backlash issue, speed should have nothing to do with size.
My apologies. I shall today as I get a break at work.
I believe that it would be more proper to start a new topic?
Yes, changing size with speed would be different. ![]()
