Cheap Omtech smoke extractor
That’s what I was looking for, thanks! In that case I will invest in a heater for my shed…
Be careful with those torpedo heaters. They burn kerosene and emit CO (carbon monoxide). I had one for my garage and had to leave a window open quite a bit. But they do work putting out heat. Maybe make a heat exchanger similar to a wood burning stove so it is vented outdoors.
Or buy a propane heater that does not need venting… It burns LPG and water is the combustion byproduct. Than is why indoor forklifts are powered by it.
Mr Heater 4000 to 18000 BTU 3 Setting Portable LP Gas Heater Unit with Dual Tank Connection for Indoor and Outdoor Use Mr Heater 4000 to 18000 BTU 3 Setting Portable LP Gas Heater Unit with Dual Tank Connection for Indoor and Outdoor Use
https://www.amazon.com/Mr-Heater-Corporation-MH18B-Portable/dp/B07Q82MG8S/ref=sr_1_4?dib=eyJ2IjoiMSJ9.lOO4Y0zlxDT75ZEHTE7KX0xCn3_EO9qNSnVuj1kwZclc8Gi_AT1aUtYV7lqUK7-5z8kOSgVPq9J36cg9gJyvYauEjqqj6QBA8XgwSx0Hstm2vYfKjtjZuQkTzACt_EyFJmmC7bKNyHCtYOblUGrf2PsJxTE5F-NyAozIMj6I74wtAnErrNXLcXM0-YVxn_nQeg3aFxD7L5PDan7ui6zzOCqfM5J1Pcwv-OPJKCQnMASjEwxdAO-h6xWWWBvsZKFrUhsji_01xB_qaq3v1xD_EislGZ8wzaJ4x-RLdjoiZpuQ7qFSQjv9cqyHx-7Nd98Sv1kzLZmv5lGsgUdfkHXW-AkIw9ACv48wk7aozeggChSd3KQ7Dn1eYDEsBYFMcu-2qc9GZpi8-_d1jzjwjoXdN_iLme1o2cf23rORu2Le-sVSIgXVMje0e_uZ6QR4aSOd.BgV0TP6_cPDCfTZVpSfOykl3jarO52budsASRnoLI3w&dib_tag=se&hvadid=695216107668&hvdev=c&hvexpln=67&hvlocphy=9004326&hvnetw=g&hvocijid=5208391636694494429--&hvqmt=e&hvrand=5208391636694494429&hvtargid=kwd-392868615086&hydadcr=24656_13611721&keywords=tent%2Bheaters%2Bamazon&qid=1736435768&sr=8-4&th=1
Sorry about the crappy URL. I do not know how to create the condensed ones.
If you want to use 20lb tanks…
https://www.amazon.com/Kohree-Propane-Converter-Portable-Appliances/dp/B07W6MTWVF/ref=sr_1_1_sspa?crid=1ZNC33ADXM9RK&dib=eyJ2IjoiMSJ9.mHXEaM0zcTMfR6nxHH35hcjAP-U6yTE0hpoV6z4v1NaxwBEhu4c8vYHG0QZcaRB7CXqK8bJTp8sdRsIjjdjXdPf5o3vPTEkW2Zhe9c7I8EHHB6G4FSoiKhhXU8W49EUNnQ65MHml52VhUNt6jctuwDNz96oy1OyIADGBYgSh3pfFVsctzU4vexK5Eh7gTxCJvuAnrNp0W74qZkaFxuC5Tb7sNLGYIhvARKeAb80605Q.uV1asJBe6u3abBhCuJ43XFVsAjjYC_UQFfrUTnKd4g8&dib_tag=se&keywords=propane%2Bbottle%2Bto%2Btank%2Badapter&qid=1736436176&sprefix=propane%2Bbottle%2Bto%2Btank%2Badapter%2Caps%2C106&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
$16, $120 for the heater.
My double car garage has a “dutch” door, cut in half hinged separately. I open the garage door about 3 inches to allow fresh air in. If I need to keep the back door closed tightly (due to wind, snow) , I would open the garage door about 8 inches. The heater pumps out enough heat to dramatically warm the garage in minutes. It has a thermostat that you can set, once it is to temperature the heater shuts off. It burns about 1/2 gallon per hour and I rarely run it for more than 10 minutes at a time once the chill has been chased out of the cement floor. The output is hot enough that I could run the garage door completely open, albeit the accumulated heat would be dramatically lower. AIr quaility is not a worry for me and there is just barely a whiff of diesel smell (not objectionable to me) when the heater shuts off.
No, I would not run the heater in the house, nor in a sealed shop. Airflow is important :smiley:
I transitioned from using portable heaters in the shop, which were both a hassle to refill and costly, to a more efficient system.
Living in the country, I use propane to heat my house and water. So, I ran a line from the tank to the shop and installed a wall heater. Now, when the tank drops to 30%, a truck comes to refill it.
This setup has been much more convenient and cost-effective for me.
After having it for a couple of years, I wouldn’t want to go back to the old way.
These heaters are also available at big box stores.
i use the Xtool AP2
works amazingly well for indoors. no need to even vent outside and replacement filters are not bad.i got it at relaese for 50% off
Amazon URLs can be shortened by eliminating everything after the “ref”.
Actually, everything after the “?” in front of “ref”.
