OK I have a Chinese 80 watt laser just received with CorelDraw as the operating system. this machine does not have a controller on the machine but uses a dongle. Can’t connect with lightburn. Any help would be great!
You have a controller board that is not compatible with LB. You will have to replace it with one that is.
Ewww. That will need to be fixed right away…
any sugestions on this repair?
Its a shame that they sent this machine to me with all the software in Chinese and cannot convert to english. thats why i want to use LB. I already use LB with an ortur laser but was ready to expand.
I ended up with a simular, if not the same machine. Switched out the controller for a cohesion 3D one, and lightburn. Works great.
Here are a couple of software alternatives you can use with your existing board.
https://www.scorchworks.com/K40whisperer/k40whisperer.html
GitHub - meerk40t/meerk40t: Hackable Laser software for the K40 Stock-LIHUIYU laser boards..
Thanks i ordered a controller from cohesion and a Ma meter last nite. just waiting now to recieve and try it out.
